Van Brunt FB
toplink
Does anyone on here have a resource for old JD Van Brunt FB grain drill parts? I particularly need drop tubes.
Thanks in advance,
Tim
John Deere used to sell a kit to convert to flexible rubber tubes on both the single disk and double disk drills. Last drill I did though was over 15 years ago so not sure if they still have it or not.
Still available from DEERE, if you can't find used ones.
Original part number JJ288M subs to individual parts, including a rubber convoluted hose to replace the original coiled steel tube.
(quoted from post at 21:06:10 11/28/15) Still available from DEERE, if you can't find used ones.
Okay, when I look that up I see that it is the tube top and tube assembly. Mine evidently was converted at some point as it has rubber drop tubes extending from the tube top. Are you saying Deere still has a full conversion to a corrugated type tube top and tube? Because that would be just north of awesome.
Tim
(quoted from post at 23:37:07 11/28/15)
Tim
Looks (at least to me) that you can still get all the parts individually.
JJ1249M (top spout welded assembly) $69.10 (OUCH!... didn't realize they were THAT high!)
M17501 (convoluted tube) $16.89
R44302 (plastic tie band) $0.09
AM11768 (NOT sure what this is.. GUESS it's ring and clip that attach bottom of tube to opener) $8.55
You better find a salvage yard. I have one messed up on my drill, all JD could get me was a short flexible rubber tube about 18" too short with large hose clamps on each end. I left it there. I have seen many with a piece of hose for the tube. Chris
(quoted from post at 06:28:16 11/29/15)
(quoted from post at 22:30:45 11/28/15) Does anyone on here have a resource for old JD Van Brunt FB grain drill parts? I particularly need drop tubes.
Thanks in advance,
Tim
Have you contacted Burrell's in Okla.?
No I have not Jim, but thanks for the lead.
Tim
Austins in Butler Mo has a drill. I purchased some parts from them about two months ago. There phone # 660 679 4080 no calls after 5:00 pm central time.
toplink hope you try something new or maybe you already tried it don't spend time lookig for parts in fact don't use a drill at
all just throw it on then spring tooth it in an be done
(quoted from post at 12:03:32 12/01/15) toplink hope you try something new or maybe you already tried it don't spend time lookig for parts in fact don't use a drill at
Wheats is in the ground. Just want to keep the drill in working order.
