Vent tube question(differential)
jp88
I am needing about three of those plastic caps that go on the end of the vent tubes on the rear axle,fuel tank,and front differential on a 1979 Ford F250.Were reworking this truck and it does not have neither of the ends,they are just open.The local parts stores around don't handle these.Where can these vent caps be found and bought?
Are you restoring on driving it? If just driving it there are a number of little crankcase filters and such at most autoparts places that fit nicely in the breather tubes.
Kinda both but functionality is more important.I had asked the local Napa dealer about it and he shook his head and said he didn't know where in the world these could be found.
I have seen many of these run up to the body, then bent over and run straight down for 2 inches or so. Just an open ended hose. Not sure if this would work in your application.
Aaron
