This spring I bought a 2002 Vermeer 604L. I know little to nothing about them and certainly learning quickly about what makes them tick. My tension on my old JD was spring and this unit has air pressure and hydraulic pressure for bale density. As I was finishing up the last few bales of hay this fall bales would all of a sudden become become very lopsided and out of round to the point I had to eject the bales. THis happened each time the bale would get to about 2-3 ft in diameter. I can't seem to locate anything wrong with the baler not do I know what I should be looking for. I tried to bale cornstalks last night and I was able to make 5' bales, but are all somewhat noticeably lopsided. Creates a lot of virbration and shaking. I have made no changes to pressures on this machine and they current are set where the manufacture recommends (in the blue range of the gauge). If I stop the baler from feeding material for more than a few seconds the bale will get worst and worst until it will completely stop. Need help from someone as to what I can look for, try, or attempt to correct in eliminating this problem.
Thanks for the help. Really desperate to find a solution.
