Vintage Rototillet
Hi all, a newbie here in need of help.
I have been asked to restore an old rototiller.
I'm p for the challenge but need help as where to get parts and list and also diagrams. Can anybody help please? :?
Switzerland? Couldn't stop my fingers, sorry. :) You are really up for a challenge aren't you!
I gave two of them away a few years ago when I moved out of New York. That looks like a late 1930s machine with a 3 HP engine. The later
ones are more common with bigger engines that go up to 10 HP.
I still have a few, but used to have a barn full of them.
I suspect you can find used parts if patient. Main problem is - these old tillers often get scrapped instead of parted out.
I used to buy parts from a dealer in the USA but the last time I did that was in 1984. They are probably long gone. Frazer Farm Equipment,
1919-23 South Wayne Street, PO Box 391, Auburn, Indiana, 46706. Phone in 1984 was 219-925-2210.
problem there is I'm in the UK so shipping would be a brute. But I would do it if customer happy. Until I find a supplier of parts should we need them. We can't build a budget for restoration.
Yes, it has a two-stroke-cycle engine. Takes a 6%-8% mix. That is 13 to 1 up to 16 to 1 ratio. Note those are the specs in the 1930s but the
newer ones in the 80s still used a 16 to 1 mix ratio.
Here are the original oil-mix instructions from 1936.
Roughly translates to "With each Rototiller, there is a cup-gauge for the oil, marked with two lines, one with indication 6%, the other 8%.
This cup of oil is filled to the mark 6% or 8% mark, and this quantity of oil is poured into five liters of gasoline. Then mix it
thoroughly."
Assuming it has a spark plug with 18 mm threads, 1/2" reach and takes a 1" wrench? Originally it would of been a Champion COM-6. That then
subbed to a Champion K-15J. Now a K13 or a D14.
