voltage drain on Ford 881
I have a Ford 881 that has been converted to a 12V system. The problem I have is the battery fully discharges overnight. The battery is fully charged when installed at beginning of evening. I even tried another battery, with the same results. Now I'm trying to figure out where the voltage drain is comming from. Any suggestions will be appreciated.
Probably the alternator has a bad diode set, or the exitation and voltage signal connections on a three wire alternator are reversed. Disconnect the alternator, leave everything else connected, and see what happens.
rickb is sending you down the correct path. could be in the charge line or the #1 spade line on a 3 wire.
you can insert a test lamp inline with the positive bat cable and the battery and if it lights you know you have a drain.. start pulling wires one at a time till the lamp goes off.
soundguy
