got my old TO-35 up and running and then noticed as i was giving it a good test drive, the voltage meter was not moving.
when i turned on the lights the meter would read negitive, but as i raised the rpm's it would not charge.
turned lights off and the meter when back to center, but not to the positive.
pecking on the voltage regulator did not help
i did have to charge the battery once earlier in the fall, so i knew the system was not working
voltage regulator adjustment:
anyone know if you can open up these cheap china made voltage regulators:
move, adjust, file or clean the points and get them working again,
i tried a couple of things that was written in the directions for installing the voltage regulator, but it still would not charge, i guess that was only to Polarize the regulator.
I have another one to install, but if i can excite this one, it would be good,
any other things to try or suggestions would be appreciated
Thanks,
Fred
would change it over to an alternator, but the tack runs off the back of the generator and so far i have not found a low RPM tach that would fit and look good in that dash tach hole.
anyone know of one.
Thanks,
Fred
anyone know of one.
