VOLTAGE REGULATOR ON JD350B
RJZAMISKA
Installed a new voltage regulator JD Pt# AT63382 on a JD350B crawler loader. JD Product services info (DUB 1691) said to atler the wiring on the alternator. As found, looking from back of alternator to the front. Black wire landed on upper left terminal on alternator with opposite end landed on lower stud on alternator on lower left. Also a green wire from the wiring harness on the upper right terminal of the alternator. New wiring said to land the black wire on the upper right terminal and move the opposite end to the GND stud on the altenator. Where should the green wire from the harness go, JD said to locate on the left terminal, is this correct ???? Regards RJZ.
