mustangmarty
How many volts should be coming off of the R-terminal from the starter to the ballast resistor that mounts on top of the coil of an IH 2444 with a gas engine? Mine shows about 8 volts with the key in the run position. Once in a while, it will show 12 volts as I push the start button, but usually only still shows about 8 volts. I have no spark. The ballast resistor and the coil together show about 5 ohms resistance across the posts, and the coil plug to post resistance shows about 12,000 ohms, so I think they are okay. Its a new coil and resistor block. There is no loss of voltage from the ceramic resistor block back to the R-terminal on the starter.
