DavidB1968
Does anyone make a voltmeter that would fit in the same place as the 6V ammeter? This is for a 1951 8N converted to 12V with a one wire alternator.
(quoted from post at 07:13:04 12/14/17) Does anyone make a voltmeter that would fit in the same place as the 6V ammeter? This is for a 1951 8N converted to 12V with a one wire alternator.
(quoted from post at 08:19:58 12/14/17) Plentiful gauges abound, but I'd rather be looking at AMPS than VOLTS in a charging system regardless if by generator or alternator. You need AMPS to crank engine over, not necessarily volts. For example, you can take a 6-Volt Dry Cell; 4 D Cells; 4 AA's, or 4 AAA batteries and they all add up to 6-volts each however, none have the required amperage to crank over an engine. In the classic Ron Howard movie "Apollo 13", the astronauts are checking their status prior to reentry and the character Fred Haise says, " ...battery shows zero volts, 2 amps". All of their electrical systems needed the amps to operate and they couldn't exceed 20 amps total without system overload.
Tim Daley(MI)
