W-4 C 152 cam
Hello all
I am rebuilding the second of my 3 W-4's. The first one went so smoothly. Only needed the basic overhaul kit (sleeves and pistons) I figured the second would be similar. ..not so lucky! After checking out the crank I decided that it should be ground so I had that done and bought the new bearings. While that was at the machine shop I was preparing to install the sleeves and noticed a crack in #4 cylinder. So I tore down the motor of my 3rd W-4 and found that block is ok. With all this time and money invested I'm thinking that I really should replace the cam and lifters because they are a bit rough looking! Does anyone here know where I can get them. I have been searching the net with no luck. May be a "dealer item"?
Thanks all!
There are cams available. CaseIH and others will have them. Use a 350 cam, or a reground cam to 350 spec for good power. caseih.com has parts diagrams on line. when you get to the model request put in farmall, then scroll down to 350, then select gasoline engine. Jim
