W10 Wheel Loader
Theodores
Looking for doors for this W10 and the front headlight assembly. It has been well used through the years, but still works! Any leads would be very appreciated!
Front view of the same wheel loader. It is a cool machine, but turns like a boat, as only the rear wheels turn (not a crab steer).
You can go to the local Napa or AutoZone and you should be able to pick up a set of those doors. Also check the ring gap on the cylinders and if you can stick your pinky between the rings i'm sure your good to go for another 20 minutes before you have to add another 5 gallons of oil. You should trade for a w5. They are a far supperior machine!
