W4 restoration
Huolti
Just starting to restore a 1949 W4. Trying to get the back hubs off to change axle seals. It looks like the hub is held on by a single bolt going into a splined axle. Tried to loosen this but is very tight. Could it be left hand thread. Any suggestions.
Yes 1 nut but beyond the splines the axle is somewhat tapered and the wheel can be tightly held. In my case, for the right wheel, I had to take off the bull gear, and take the whole shaft and wheel to a machine shop and they used a 10 ton press to get the wheel off. I had tried all sorts of pullers and heat to no effect. The other side came off with no effort at all.
Had to take the whole trumpet and cast wheel to the machine shop to get the casting off. 100 ton press jumped and shook all the dust off when it came loose...this on a 930 Case standard.
I seem to recall my I4 being stardard threads, but it was tears ago when I pulled the wheels off of mine. I actaually took the
bolts out, and drove the thing around the field to get the hub to break loose.
Both bolts are right hand thread. They can be a bugger to get out. Lots of penetrating oil and a little patience will get them off. That is the easy part. I did a SW6 years ago and it took me nearly a week to get the hubs off. I had a very heavy duty gear puller that I borrowed from my diesel mechanic neighbor to apply pressure. I had a propane weed burner, a good sized chunk of oak and a sledge hammer. Pressure, heat and hammer with application of penetrating oil and they finally came off. Did it a little each day, giving the penetrant time work. They are a tapered spline so they are on there good.
OTJ
