W6 clutch specs
54robbie
Can anyone tell me the release finger measurements for the pressure plate on my W6 Mccormick. If got 2 that are lower than the third. Tried to google it but not much luck.
Thanks.
I'm thinking your pressure plate has failed. You shouldn't need to set the finger height on those. They come pre-set to the correct height, and I'm not even sure they can be adjusted. That's why the information isn't out there. It's not necessary.
I dont trust any pressure plate to be right, have found many out of whack even new from the cheaper ones to the most expensive.
Here ya go -
Click here
I agree with Jon below, several years ago when I put pressure plate and clutch disc that I got from IH dealer for SMTA got it together and wouldn't release. Had to split it and set fingers on pressure plate as they were off
A couple of years ago, one of the members here said I wasnt buying the right ones, and said I should have been getting Reliance parts. Funny thing was, most of what I had to adjust were Reliance pressure plates.
Just to clarify, this is not a new replacement clutch nor is it a worn out one. This one was installed years earlier by somebody that didn't know what they where doing. Everything is still in really good shape.
Thanks for the Blue Ribbon manual.
