(quoted from post at 07:06:06 12/17/21) Had you tried getting the pistons and sleeves out before you removed the block frm the rear end of the tractor you could have put a jack under the piston with a wood block then with the weight of the engine on there hit the top of the block with a sledge hammer after laying a hard wood block on top of the engine block. You would gain the engine block weight helping along with the gravity. Lot easier to hit on top than trying to hit up from underneath.
(quoted from post at 18:38:16 12/16/21) I'm afraid that that was one of the easy ones,#1. #3 & #4 have more rust. The only way I got this one to budge was after soaking it with Marvel Mystery oil a couple weeks I put a lot of pressure down until I snapped the top ring right off the sleeve, then I knew it had started to move so started driving it back up with wood and a sledgehammer.
