W9 radiator gasket
Jim Ma
Does the W9's(C335) core have a gasket between the upper and lower half's? I just took apart one and there was no gasket on either.
thanks
Jim
It must be very deteriorated to the point of no recognition. I cant seem to find a gasket online for this, RTV black it together?
I would suspect you could make one out of an old inner tube. They are usually just a rubber gasket. No sealer used. The rubber seals it.
As per picture:
Bob
Suggest you get new hold down straps 11 item and all new fasteners . I use permatex to seal top and bottom both sides .
I would recommend you have an assistant to help you assemble . Its very awkward to try and hold all that together .
Take your time ,it will turn out good .
Olsens gasket will make them for u. They are decent on price I felt. I have also used the cork gasket that comes in a roll.
Where did u get a radiator core?
I have made my own gaskets for my JD style D's........:)
Cork Buna-N Rubber Blend Sheet
If in Canada I always use Contact-Cement ....:)a 3M Product..........
Bob...
