I did not come up with a listing from Champion but AC Delco lists C73 as the correct plug. That crosses to a Champion W10. You can use a W14 for light duty or if necessary to keep from fouling, a W18 for parade duty.
I have also found the Autolite #3076 listed for the W9 on Steiner's site.
I crossed the Autolite number to Champion and it came back a W10 W14 W18 and W20
The Autolite #3076 also crossed back to Champion 429 518 and C16C ??????
I would go with Champion numbers Owen posted.
simple,take an old plug with you to napa or whoever , from there they will give you the correct plug. there is two tread sizes as the early tractors had the big plugs which are the W series, or it can be the D series in the champion line.if they know their plugs i am sure there is no problem to get the size and heat range you want.you say its 1948 so i am sure its the same ones as in the M and W6 which is the D16 , and from there select your heat range for the tractor usage.
