Wagner loader question (International 330)
curtisjade1
Hi I just recently got into restoring a 1957 international 330 and I have now replaced/repaired all of the bad parts stripped the whole thing down painted it and put it back together
and now that I got it running again I can't seem to figure out where to fill the hydraulic fluid.
I have filled the tank underneath the seat but that doesn't seem to connect to the loader or controllers anywhere.
I am thinking maybe I am supposed to fill the actual loader with fluid because thats where the hoses on the inlet on the pump and the outlet on the controllers hook up to am I right on this?
That's for sure,
If the loader has it's own pump, then it's hydraulic system is completely independent from the tractor's system.
Follow the inlet to the pump; it comes from the loader’s reservoir. Oftentimes, they are hidden in an upright leg or support.
Allan
Curtis: Most wagner loaders use a separate hydraulic system with a front pump as Allan suggested. The Wagner I owned used the loader pipe subframe as a reservoir, and the filler neck was just forward of lift arm pivot.
