wagner loader
startin out
ihave what i believe to be a wagner wm4 loader on a 46 2n anyone know what fluid capacity is? loader ran well when i finally got tractor running after 3yrs of sitting all lines and valve leaked so am replacing. would like to know how much hydro/tranny fluid it holds thanks startin out
Sorry I can't tell you how many gals but I made a nice little pump out of a furnace oilburner that I picked out of the steel pile at the dump stripped it apart except for the motor,a section of the frame and pump.It sits nicely on top of the 5 gal pail with a 1/4" ID. hose thru a drilled hole in the pails cover and a 8' section of hose to reach up to the fill hole.Plug er in and reach for a tall frosty. I like it so well I use it to fill the tractor as well neat and no spills.I use the same tractor hydro/transmision oil.
(quoted from post at 07:28:05 01/12/13) ihave what i believe to be a wagner wm4 loader on a 46 2n anyone know what fluid capacity is? loader ran well when i finally got tractor running after 3yrs of sitting all lines and valve leaked so am replacing. would like to know how much hydro/tranny fluid it holds thanks startin out
The manual says to fill with 4-1/2 gallons.
TOH
