Walk Behind Brush Mowers
Pipestem
Anybody have experience using a walk behind brush mower on hill sides? I have some places too steep for a tractor mounted brush cutter. Too much to do with a hand held brush cutter. I am in West Virginia so I am dealing with significant slope but much of it should be workable with a proper unit. Some people I know have used Gravely walk behind units in the past but I don’t think they are manufactured now and parts for a used one may be an issue. I know DR makes them And I’ve looked online at one called Billy Goat.
I have a DR Brush mower. It works fine. BUT, be sure to find one with the locking drive axle. Newer versions have "power steering" that only means a separate brake on each wheel.
The "dashboard" should have a separate lever to push forward to engage the locking mechanism.
Ken
Take a look at KUNZ products in Mendota Il. Not sure if they have what you want but are very well built
I use a DR wheeled string trimmer in the alley behind the shop.
It works, but it's a lot of work for such a small area. Awkward to maneuver.
It's not real steep but rough, small rocks, obstructions.
My complaint is being pelted with flying gravel and anything else it can pick up.
I think a good string trimmer with a shoulder strap would be easier.
Pipestem,
I have a billy goat brand walk-behind. Look at how it is built, heavy gage metal, welded, Kevlar belt, foamed tires, dana transaxle.
This thing is heavy, and it walks over woody brush, stems about 1 to 1.5 inches diameter. It will work you into the ground.
We paid dearly for it, and do not regret getting the item of heavy duty wwe wanted.
D.
On very steep ground I would want to know where the oil pick is and how it works. You don't want to starve the engine for oil.
I wonder if their is a battery driven unit out there today.
Dave.
Why not just use your tractor and back up the hill with mower engaged and drive back to bottom and take another swath until done????---------------Loren
This is just an idea,but why don't you just use a weed wacker/string trimmer once to cut down the heavy brush,then from that point on,keep after it with a push mower..I live off a shared 1/4 mile driveway in the hills of PA,and I of course maintain my side of it,which runs the entire 1/4 mile.It is way to steep operate a tractor on,so I spent about 5 or 6 hours with the weed wacker one day,now I just spend 20 minutes with a push mower every 2 or 3 weeks.HAPPY THANKSGIVING!
Rock
