Wanted New or Good Used
DickL
I would like to replace my bend over devise before it becomes totally unusable. The one I have seems to start flashing the warning light after only around ten minutes. With continued use the over load trips in about another ten minutes at best.
Trying to get the paint and dirt off the final drives of an Allis Chalmers C. Three different nights with this defective devise and I still have not completed the task.
The bend over device. causes considerable distress between the upper and lower spectrum's usually between the head and final drive.
Only factory parts can now be replaced, the old ones once wore usually will be non serviceable.
More ane more parts become avaliable as the years pass. Probly never will be able to get a new wiring harness.
DickL this is your Government calling to inform you , you didn't attend the end of life classes like was mandated. Therefore you will forfeit all government servicing of your body!!!!!!!!!!
Also if you would have read the fine print , you would see that working on junk such as you have been , voids your new health plan.
Sir if you will just please lay down and die it will be the best for your country.
Sincerely OB and friends
i have the same problem, and its almost become a total malfunction, since im not a minority, [ in a state run litterly by them] im not entitled to any disability[ somebody has to help make their welfare money] so instead, im trying to invent a replacement device to provide back suport and function, so far its not as easy as i thought lol, i figured out it needs to be hydraulic not punematic, due to noise, at least i think so, working around a lower suport like a gunbelt, a cop"s not a old west gunfighter"s, and a upper suport like a safty suport vest with at least 4 servo"s to provide 4 different directions of movement this would have to be computer controled to a point so as to have them work togeather, which means riging some kind of sensors to provide input as to which way the movement is desired, dont know if there will be any market for that or not but it might help me and a few others who have worked like a dog all there lives
