Wards twin row engine problem (Hercules engine)
Dan J
Ok, Got the tractor running, Put 2 new rods in (#2&3) Problem is #3 cylinder will not fire. It has great spark, I have tried other spark plugs and wires, wires are correct. hard to tell about compression as it is crank start but it will blow your finger up and I tried a guage with the engine running and got somewhere between 35 and 50#. Makes no difference to the engine if the spark plug wire is on or not. Valves looked ok but I did not remove them, they are set to specs. I am stumped. Any ideas?
Make sure you don't have a couple of plug wires crossed. Possibly a bad distributor cap? Possibly a bad vaccuum leak on just that cylinder?
Rusty, The wires are in correct position, manifold is good with new gaskets, Mag is rebuilt and spark is great. All other cylinders are firing correctly. Thanks, Dan
That amount of compression is not really enough for that cylinder to fire. If that is what you have with the engine running, you would probably have much less than that at cranking speed. I guess the first thing I would do is to put 5 or 6 full squirts of engine oil in that cylinder, and try your running compression test again. If your reading goes up substantially, you are losing compression past the rings. If it doesn"t go up that much, your valves are leaking. A general rule of thumb is that you need 40 psi compression at cranking speed on a gas engine for ignition to take place.
Bring No3 piston to TDC on the compression stroke and then apply air pressure through the plug hole and see if it will hold air pressure.
You probably will need to fabricate an adapter to fit the plug threads in the head. If it won't hold air pressure your valves are leaking or the rings are leaking. Did you stagger the ring gaps or measure that cylinder for wear? Hal
