Warmed Up to 30F
rusty6
At a high of 30 degrees yesterday was the warmest day in over a week so I took advantage of it. Pumped the summer diesel out of two tractor tanks and mixed in some fuel thinner/cetane booster so the fuel will flow this winter. The CIH Magnum I just filled up with summmer diesel as I don't plan to run it in winter. Parked in the back of the quonset. Still enough daylight left so I was able to transfer some tough wheat to aid in the cooling process. It stores fine at 16% moisture as long as it is cool. Found time to shoot a few minutes of video.
Warmed up to 30F
I like your auger with the little gas motor. Thx for posting. Our corn wasnt drying fast enough , even with the LP burner running. They took 4000 bushels out and let the rest dry some and then put it back in on top. Just like you did.
