warter pump
anew
I have a 1951 super a farmall with a 113 engine with out a water pump .does anyone know what it would take to install a water pump on it ,just a water pump and belt or does it intell more parts.Thanks
It works by the Thermosyphon principle and doesn't really need a water pump unless you are having overheating problems with it.
If you still need a pump, a water pump for a Super C will fit right on it. You'll need the Super C fan belt and you'll need to bend the fan blades out at the ends to keep them from hitting it. It will go on in place of the bottom water inlet to the block. If you take off the radiator, it's an easy install.
You may also need to re-engineer the top bracket for the generator.
