37chief
- Location
- California
Does anyone know what causes a washboard road. Seams just driving straight, the road should stay flat. Any thoughts? Stan
I have never seen washboard from a blade. You can make those big roller coaster "whoop de doos" with the blade if there is a lot of slack in the linkage. (I've done it) but they are many feet apart. Those annoying little chattering ripples on the corners are from slipping tires. On rare occasions I will see this ripple effect out on the level on a straight road through sandy soil. Kind of a "standing wave" effect in which the loose sand is pushed by the high speed rolling tires and forms ripples as the tires jump over that wave. Multiplied many times over it can become undrivable at high speed.(quoted from post at 20:00:56 11/30/18) On gravel roads you can get the washboard efect with just your 3 point hitch blade. The wrong tilt of the blade will make it. And I have never seen it at intersections like others are saying. It is always full length of road or your driveway.
(quoted from post at 21:02:03 11/30/18) If they were caused by the grader patrol, they would be at an angle to the road. The graders never run with the blade straight, they move the windrow from side to side.
(quoted from post at 08:38:00 12/01/18) I haven't a clue what actually "causes it" but after reading all of the replies below, it appears as if the YT crowd have a lot of their own theories. I hope that someone with a PhD in road construction or geology steps up to the plate and sets the record straight before this gets buried on page 2 or 3.
(quoted from post at 06:38:00 12/01/18) I haven't a clue what actually "causes it" but after reading all of the replies below, it appears as if the YT crowd have a lot of their own theories. I hope that someone with a PhD in road construction or geology steps up to the plate and sets the record straight before this gets buried on page 2 or 3.
(quoted from post at 18:38:28 12/01/18)
I should run away from this one but here goes, as a motor grader operator/ operator training instructor. I can tell you one thing. Washboards are caused by traffic, Pot holes are caused by motor graders or rather the operator not maintaining enough crown/ drainage. I can usually follow the wash boards right back to the drive way of the lead foot who creates them. Sometimes to the point of where their
automatic transmission shifts! Spinning or sliding tires cause washboards. Gravel pack also has a limit to it's cohesion, once a vehicles shock wave is greater than the cohesion factor the crust will yield and washboard. Thats why flat straight roads will washboard because speed magnifies the shock wave. I have a Sandvic pick upfront, or I can go more aggressive and use my Grader bit pick. AS for the grader causing the washboards only a rookie or an operator who doesn't care would ride out a grader hop. You can feel it in your seat and correct it the instant it starts. My Grader is equipped with stable blade or bounce control, I turned it off because I can feel and correct it faster than the sensors. A grader operator can do lots of things to minimize the washboards but he can't work miracles especially in dry conditions. The Smoother I make em, the faster they go, the quicker they turn to crap.
(quoted from post at 20:10:19 12/01/18)(quoted from post at 18:38:28 12/01/18)
36F30, I don't see why you would want to run away from this. It appears that most other posters have said the same things.
(quoted from post at 20:24:15 12/01/18)(quoted from post at 20:10:19 12/01/18)(quoted from post at 18:38:28 12/01/18)
I have to train new operators to deal with the public and their misconceptions of what road graders and their operators are capable of. Conditions change daily sometimes hourly. I often tell them the day they think they know everything and there is nothing more to learn is the day they become worthless. One of our veteran operators was stopped by a gal who told him "I don't know how to run one of these but your doing it wrong". There are some great operators who just can't handle dealing with the public and quit. Not always a good thing to open yourself up to it.
