..and such would have prevented careless re-assembly without washer that resulted in more than one Boeing 737 crash.(quoted from post at 08:09:02 09/21/20) A few years ago I worked with the fastening engineering department of a major automotive OEM to organize their fastener catalog in our product data management system. This catalog had about ten thousand fasteners, but only a few hundred of those were considered "standard" fasteners that were approved for use on new designs. The engineers told me that there were NO washers currently approved for use! If an application required a washer, they had to use a bolt, screw or nut with a captive washer. Sure eliminates a lot of aggravation in the plant.
ctually that is somewhat like the Boeing 737 incidents, in that without the flat washer, the nut would fit right thru the part that was behind it, thus detach. Why hole so large you ask? Because the "bolt" was acting as a shaft and needed to rotate in the mechanism, so it was greater in diameter than the turned down and threaded portion for the nut.(quoted from post at 10:49:30 09/22/20) How many times have you seen a bolted connection with a flat washer then a lock washer then the nut???
Makes no sense to me, to put use a flat washer with a lock washer on it too.
he flat washer spreads out the load, the lock washer keeps tension on the nut. Two parts for two purposes.(quoted from post at 10:49:30 09/22/20) How many times have you seen a bolted connection with a flat washer then a lock washer then the nut???
Washed would have kept bolt from punching hole in fuel tank. https://web.archive.org/web/2017092...lines120/ChinaAirlines120_Downstop_pop_up.htm(quoted from post at 07:22:26 09/23/20)he flat washer spreads out the load, the lock washer keeps tension on the nut. Two parts for two purposes.(quoted from post at 10:49:30 09/22/20) How many times have you seen a bolted connection with a flat washer then a lock washer then the nut???
(quoted from post at 08:22:26 09/23/20)he flat washer spreads out the load, the lock washer keeps tension on the nut. Two parts for two purposes.(quoted from post at 10:49:30 09/22/20) How many times have you seen a bolted connection with a flat washer then a lock washer then the nut???
