ron miller
What would you use to clean engines the sheet metal is off trying to do a good job we dont have hot water .
good evening ron, I use sunlight liquid dish soap, it do's a great job on burnt on dishes and pans, of course it will do a better job with hot water but it works with cold as well. and idea for your no hot water issue, look on cr or local papers, online etc. for a 40 gallon gas or propane hot water tank, you put a garden hose fitting on the outlet and inlet, propane connecter from a 20 or 40 or 100 lb. bottle, turn on your water supply, when the tank is full, light the burner, go have a coffee, come back hook up your pressure washer, turn on the water and your away. 40 gallons of hot water will be more than enough to wash your tractor. I have rigged this system up twice for me and several times for neighbors. works great.(quoted from post at 19:49:47 01/25/18) What would you use to clean engines the sheet metal is off trying to do a good job we dont have hot water .
