truckerlary
When I purchased this 706 it had been setting outside for about 5 years and the cover on the high-low gear box had been removed and
just layed on top of where it went without being bolted back down. Long story short the gear box had around 5 or 6 gallon of water
in the bottom. I removed all 5 drain plugs in the bottom and drained it what I thought dry. Put 15 gallon of new oil in and started
tractor. Checked the dipstick and it is very milky. Going to let the tractor set and see if the water separates to the bottom where
I can drain it off again. It was suggested that I drain it dry and put Kerosene or diesel fuel in after draining and run it a
little bit to help clean the inside out. Is this a good thing to do? Can't figure where the extra water came from. The tractor
hadn't been run all the time it was parked and the oil wasn't mixed with water before I drained it the first time. Any ideas?
