I bought this NAA recently. It has been sitting idle "for a while". I finally have the engine purring like a kitten. Now for the back half of the tractor.
The hydraulic fluid has a little moisture in it as was expected and I understand, quite normal. I'll work it out as I use the tractor since the lift works so well and does not leak off very much.
The transmission was another matter. I took the top cover off the transmission to replace the starter switch. It was within 1 inch of the top with oil. I knew that 9 qts of oil would not have the level up this high. I took a siphon hose and worked it to the bottom and siphoned 2 1/2 gallons of water out, leaving some very emulsified oil and water. I have since used my handy 4 foot cheater bar and 1 1/16 socket to remove the plug from the transmission and drained the emulsified mess out. Left it draining overnight.
Now, what should I do to clean the rest of the junk out of the transmission? Leave it and put fresh 80-90wt gear oil on it and let heat burn the rest of the water out?
I have put on a new shifter boot and top cover gasket to reduce re-occurrence. This much water had to have been rain water over a period of years.
