Water in oil
drhill01
I have a 1940 or 50 (not sure of exact year) Ford 9N. I had an issue with the water and oil mix. I drained all the oil out and left the plug off for a couple of days. I replaced the head gasket and torqued everything down. After a couple of hours I decided to fill the radiator and let it set. With the drain plug still out I noticed a couple drops of water under the tractor after a few hours. It wasn't a lot, but this still shouldn't have happened, right?
First of all, if it's a 9N, 3 speed transmission then it can't be a 1950. If it's an 8n, 4 speed transmission it can't be a 1940. Then when you had the head off did you have it checked for flatness? You might have to have it re-surfaced. Then make sure the pistons don't contact the head.
(quoted from post at 11:38:53 03/28/21) I have a 1940 or 50 (not sure of exact year) Ford 9N. I had an issue with the water and oil mix. I drained all the oil out and left the plug off for a couple of days. I replaced the head gasket and torqued everything down. After a couple of hours I decided to fill the radiator and let it set. With the drain plug still out I noticed a couple drops of water under the tractor after a few hours. It wasn't a lot, but this still shouldn't have happened, right?
When you refilled, did you use water or antifreeze!
drhill01,You say ,1940 or 50 (not sure of exact year)
If it has a pressurized radiator,and you still have the oil drained out.Put a drain pan under it and get a pump up radiator tester pressurize the radiator and look for drips out the drain.If it is still leaking drain the block and pull the head again.Have it checked for flatness , only plane as much as needed or you could have piston clearance problems.Then magna fluxed for cracks at a machine shop.Then I would replace the head with a FelPro head gasket.Start and run till operating temp then re torque head bolts.
(reply to post at 15:31:12 03/29
Wondering about where you live and if you experience freezing temperatures, which could of caused a crack if not using anti freeze.
What is the history of how this came about to find water in your oil.
Is water still dripping out at the present time?
If so, you might need to again, pull the head and have it magna fluxed and have it checked for warpage.
(quoted from post at 16:31:12 03/29/21) Water
Too bad, antifreeze would have told you more. a bit of water may not be anymore than residual condensation draining out.
Good luck
