Water in the engine oil.
Ok i have a 1936 farmall f-20 that i started 8/4/09. i went to fix the oil guage and the oil came out loke a soup liquid. so i thaught it was just because it hasn't run ing 32years. I drained the oil on the engine and whater came out then the soup like oil. What could be makeing the water in the oil, could it be condensation, or just from cleaning the engine just form sitting for 32 years??
I would pull the pan and see if any water is dripping. You may need to put a few pounds of air pressure on the system and see if any leaks are visible. See if the engine is just sludged
up from sitting. Hal
