On my TO 30, does the water pump have a 'weep hole' that allows coolant to dribble out when the seal or bushing is wearing out?
Short answer... Yes.
Long answer... Here is an exserpt from a forth coming article I wrote for the Ferguson Furrows...
"The water pump used on the TO-20, TO-30 and TE-20 is an impeller type and is driven by the fan belt. The pump turns in a double row, sealed, pre-lubricated bearing that does not need extra lubrication. Both a stamped brass and a cast iron type impeller have been used in the water pump. The water pump has a spring-loaded rubber seal and graphite washer. The washer turns on a machined face to prevent coolant from leaking around the shaft. If a leak does occur, a brass slinger ring throws the coolant off the shaft to protect the bearing. This coolant then drains out a hole in the water pump housing. Coolant draining from the bottom of the pump housing is an early indication of a seal failure."
Thus, your water pum seal is starting to go and you'll want to get it fixed before it fails.
Jeff
Thanks for the informative reply.
As soon as the barn warms up, I'll pull the old pump. Think I'll have the radiator flushed and pressure-tested while I'm working on that end of the engine.
