Water temp gauge
If replacing, I just put it back where the factory one was.
If you got a really old enough machine, that it don't have one, don't worry about adding one. It likely don't have a water pump and pressurized radiator cap neither,
and has a thermosiphon system with an oversized radiator. You don't need a gauge with those. They run a little on the hot side anyways, and they'll boil over and let you know if things get a little to warm.
The original location was on a little bracket on the governor housing. The 140 is a different part number than the earlier tractors. I'm pretty sure the earlier one is available as a repro.
It is illustrated in the parts catalog.
