old
- Location
- Camdenton Missouri
A couple days ago I got up to take a leak at around 5am and found I had no water. Went out to check what was going on in the well house. Found that one of the 2 power wires from the breaker panel was not making good contact so tapped on the switch and it kicked the pump on and I went to bed. Forgot about it till it happened again. Went to fix the problem and the screw broke off. Switch still works find but the wire is just on it by the pressure of a bend I made. I know if I try to drill the screw out I will mess up the tread so thinking I could drill it out slip in the wire in that hole then solder it in.
Does that sound like it would be a good and easy way to fix it.
And no I do not want to replace a $40 pressure switch if I can get a few more years out of it
