waterpump blues
jasonteem
How do I test the water pump? I can not tell if coolant is circulating when I look under the fill cap. I can not tell if it is flowing or just jiggling from vibration.
Start it Up COLD, as it warms up You should see a flow starting as the thermostat Opens... and the radiator Tank will Get Noticeably Warmer Quickly!.. Larry
If you have a radiator with the offset neck on it, you will not see coolant circulating. Run it and feel for heat in the hoses.
