waterpump blues
jasonteem
How do I test the water pump? I can not tell if coolant is circulating when I look under the fill cap. I can not tell if it is flowing or just jiggling from vibration.
Is the tractor getting hot?
Could have a stuck closed thermostat. Coolant may not flow visibly until the tractor warms up and the thermostat opens.
(quoted from post at 05:27:16 02/04/17) How do I test the water pump? I can not tell if coolant is circulating when I look under the fill cap. I can not tell if it is flowing or just jiggling from vibration.
isconnect top radiator hose and start it........you will know......and then clean up. I've done it & it does work in finding broken and working pumps.
