wc oilpan removel
I think the clutch inspection plate needs to come off too. Otherwise, it's just a lot of bolts and a good tug. Might need a small pry bar to pop the gasket loose.
AaronSEIA
I have found it alot easier to remove the front motor mount bracket. It gives you alot more room to work, most noticably on reinstilation. Those end gaskets can be tricky if not carefully placed.
