WC plug wiriing diagram
GRC
Need to verify the plug wiring on my 48 WC...
Distributor Cap to Plugs...
Firing order is 1,2,4,3...
You have to bring # 1 cylinder up to TDC on compression stroke and remove the cap ans see were the rotor is pointing. Start there with the #1 plug wire and work clockwise with the rest.
Standing behind the magneto you might find #1 to be on the top left.
2 of my wires fell off the distr cap together...
I wanted to make sure I plug them in correctly...
I believe, if I'm behind the magneto looking forward, number 1 cyl is on the upper left...
I'm also guessing 2,3,4 to CW from there...
I believe you are correct as to the #1 position of the distr cap. Positions 1 and 2 were the only ones in question, for 3 and 4 were not removed. Do you know of any diagram or picture that shows this ??? My maintenance manual only shows the engine being rebuilt. Please Advise b4 I fire up the tractor.
This pic should help. Hal
