WD 45 Brakes
DavidK
After a week of trying to get the pin out it finally let go. Do I have to disassemble all the pins and snap rings and cotter pins from the top of the shoes to remove them? I took some of it apart but neither side will come out. Thanks
Take the nut off of the adjusting bolt and slide the bolt out. Wouldn"t hurt to back off that bolt that goes through the rear of the brake housing. Everything should pull out the top. Use "never-seize" on the lower pin during reassembly.
