WD-45 Problem
Dale M Crow
I am wondering where to start to find the following problem.
I was using a 3 point snow blower when a shear bolt broke, drove to the shop, replaced bolt, checked for obstruction, drove back to where I left off blowing, disengaged hand clutch, pushed clutch, engaged pto, started to let out clutch and the motor bogs down, disengaged pto with no improvement, now the only way to keep motor running is with the clutch petal pushed. Could not move the tractor or run the pto, had to pull tractor to the shop.
Where do I look first to fix the problem?
You most likely have a problem in your PTO gear system. Probably broke a tooth at the same time you broke the shear pin, and the broken tooth is wedging inside. You might be able to turn the engine backwards with the clutch engage to free it up, but it will probably happen again, maybe breaking something else. Maybe you can fish out the piece with a magnet by removing the PTO lower housing. I think I would do that first, you will learn a lot more after doing that.
I assume the shear pin was the one under the tractor that couples the PTO shaft to the output shaft of the gearbox under the transmission..??
I have always drilled both ends of that bolt and safety-wired them so that if it sheared, it could not come half-way-out and lodge against the transmission bottom..
Could that have happened when the pin sheared, jamming the shaft rotation..??
If it turns out to be a gear tooth, have the "ears" Magna-fluxed (on the top of the PTO output gear-box)..that is a place where they can crack..
Best of Luck to you...
Ron..
Did you shift when you clutched? Sounds almost like your transmission is stuck in 2 gears. Try shifting out of gear and see if the tractor will move while in neutral. Otherwise you must have something messed up in the PTO gearbox like jammed gears.
I"m with you Bill. It might be a coincidence, but it does sound like the shifter is worn and allowed the tranny to get into two different speeds at once. Pretty easy to check this out; pull the shifter handle and "peer" down in there with a flashlight.
Had that happen a couple of times with my WD before I welded up the end of the shifter and reground it to work right. Only happened once on my WD-45 before I fixed that one too.
Finally had a chance to look at the tractor, first checked that the transmission wasn't in two gears, then hand clutch. The problem was in the Pto, the needle bearings in the idler gear piled up and locked up the idler gear.
Thanks for your help
