WD 45 pto housing question
KS 640
What is the size of the stud bolts used to attach the housing to the power tube, and the size of nut used for a WD 45?
Nuts are 3/8 fine thread. 9/16 open end wrench. You may have to back off the nuts a little bit at a time as the pto box lowers. Just curious, why are you removing this?
Several years ago had to replace a bearing and reline the brakes and its now leaking oil around the pto assembly. Noticed one of the bolts is
stripped and needs replaced.
