wd-45 update
bobs old iron
changed the oil on this wd 45 i bought, oil had a lot of gas in it, about 2-1/2 gals, put 20-40 oil in it, took away a lot of bearing noise, put a can of rear main sealer, ran it for a while, need to run more to see if main stops leaking or slows down
i guess it would have brg. noise with 2 1/2 gallons of gas but i dont think it had that much. did you drain out 4 gallons of oil then? nothing stops seals from leaking either than replacement. might have brg and crank damage now. what is 20-40 oil?
