WD-6 issues
Maestro
I need a little help here. 3 questions about a McCormick WD-6 I have. 1st. It seems to be fueling up around the exhaust. The hardest this thing has been pulled for years is on a small square baler. What can I do to prevent this from happening. 2nd question, It sometimes seems as if it isn't running fast enough on gas when it starts. Sometimes it does and sometimes it doesn't. My WD-9 runs much faster. Last question, It seems as if the controls are backwards on this tractor. The trip lever and the throttle lever work backwards. To increase the speed of the tractor you push the throttle lever up and to slow down you push it towards the platform. The trip lever is also opposite of both my WD-9's. IS this common or has somebody messed something up here. I would appreaciate any help someone can give me. Can't find anything in my books. Thanks
The slobbering is caused by light loads and loafing about. To repair, work it hard for several hours. There is no throttle plate in the carb, it is just open all the time. It is small enough to prevent over speeding the engine. If the mag/dist. is timed correctly, it will run strong enough to start.
The throttle seems correct. The trip lever (I assume it is the changeover lever) is also working correctly, JimN
Like JimN says the exhaust slobber is from not working the engine hard.
Regarding the intermittant low RPM's on gas, make sure the spark timing is set correctly. Also that the spark advance mechanism not sticking or broken.
Also I recall years ago being able to slightly increase RPM's on the gas side by increasing the air valve gap in the carburetor. (Air valve sits on top of the carb where it bolts to the manifold). However the gap is pre-set on some (later production?) carbs and cannot be adjusted.
