WD-9 camshaft problem
Rob F
I have rear engine oil leak whick I believe is because the camshaft has moved back and popped out the rear plug on the back of the engine. I found this plug in the clutch housing area. Has anyone ever run into this before? I haven"t torn down the front yet to inspect but the camshaft retainer or the gear must be worn to have allowed this to happen. Very strange. If anyone has come across this before any info would be appreciated.
the camshaft retainer is there to keep the cam from moving forward.as you say the gear must be worn or is coming off the shaft.
