WD pops through exhaust
Michigan Bob
I have rebuilt the carb and checked timing, cleaned gas tank and changed plugs and points. My WD has a distribtor. It still continues to pop through the exhaust when running, but not if it's pulling hard. It only does it when it is sitting stationary especailly at idle or going down a hill.Does anyone have experience with this problem and other possible fixes. The tractor runs fine other then that , but I'd it to purr like a kitten.
Thanks,
Popping going down a hill is just normal..
If the muffler is not a good fit, it will pop a lot more..
At idle, it could be from a worn bearing in the distributor..worn valve guides, or bad valves..
Have you checked compression, or checked valve lash..?
I definitely like the original "Nelson" muffler the Best..it has that "Sweet Sound" of a WD....!!!
Nothing else sounds like one..
