WD throttle linkage
41C
Good morning,
I have a throttle linkage question. Started my WD yesterday to mow but the rpm’s would not increase so I shut her down. I checked the throttle linkage and everything seemed normal. I started her up again with the same result. While checking around with the engine on, the throttle worked correctly at the governor but would not control the carb. I moved it slowly by hand and the rpm’s increased. Anybody have ideas of what the is could be?
Check for broken or missing springs If I remember right with out going out and looking there is a spring that hook from the throttle to the gov in some way and if it is not hooked up or gone you will have that problem
I took the gov out today and the only spring I saw was hooked as it should. Is there another inside I would need to take the cover off to find?
Thanks again
