My 1953 Allis Chalmers WD has an identity crisis. It seems to think it's a Lincoln Welder instead of a tractor. It has been sitting for a couple of years and I'm trying to get it running again. I worked on it last spring and when I hooked up the battery, there was lots of sparks and smoke. I got frustrated and walked away, but now I'm back at it. I put new plugs, wires, cap & rotor, points and condenser, and coil on. I removed all the wiring and I'm starting from scratch. I ran a wire from the coil to a switch and hooked it on at the starter lug for power. I checked for continuity through the coil and then attached the positive post of the battery to the starter. When I went to hook up the ground cable, it started to spark to the point that it took a chunk off of the battery post. I removed the coil wire from the system and tried again, only having the starter connected and again with the fireworks. It's got me stumped.
John
John
