wd4 oil pressure
RL135
Looking at a wd45 to buy.I need to know what the oil pressure should be.It shows about 10 lb at idle and reved up.
Allis engine are low pressure oil type engines and if it has numbers on the gauge then it has the wrong gauge on it. But yes 10psi is good for one. A true Allis gauge should not have numbers but have a normal range and a low range sort of thing on it. The engines get oil pressure by way of the oil filter and the wrong filter will cause major problems and no PSI
