wd45 front crank seal no.
Does anyone know the Napa or National seal no. for the front crankshaft on a wd45. I have put two seals in it and they both leak. I would like the thick seal with the felt towards the front. The AGCO seal even leaks. There is a slight groove in the crank. I dressed it with a little very fine sand paper. It still leaks though. UGH! Any suggestions are greatly appreciated. Thanks.
Get a speedi sleeve that will help a lot. Not the seals fault crankshaft needs a tighter fit between the seal. You can get the sleeve at Napa or any auto parts store. You need to do a little measuring.
