WD45 serial number location
Jon Ediger
I have looked on the leftside brake cover and found:H304 and AM-3634-7 Is one of these the serial number,if not does anybody have a picture of the sreial number location they can email me? I'm getting ready to sell this tractor and want the right info. thank you,Jon Ediger,Ava,Mo.
The serial # will be hand stamped, not cast in and will read WD######. There is a chance it has no number if it's a replacement rearend or it may take some scraping and brushing if it's lightly stamped.
Hello from the Lake of the Ozarks. The serial number is stamped below the brake cover not on it. There is a flat spot on the rear end in that area that should have the number on it. Be careful how you clean that area to see if because it is easy to clean the number right off of it. I use a rag and carb cleaner to clean it up to be seen. Sorry not sure what happened to the picture I had that shows where it is
