D beatty
I don't know if anybody can answer my question. Is there any casting numbers that can tell you if the engine in a 45 is a 226 45 engine or a 226 D17 engine? I know the D17 226 puts out more HP. I pull my 45 and in a 6,000lb class I never run out of power or pull engine down. .
(quoted from post at 22:41:56 08/19/17) I checked the RPM and it was 1750 at full throttle. Block number started with 45 and ended in G.
pparently someone changed the governor spring if your RPMs are that high.
You definitely have the WD45 engine. That is not to say that someone didn't change the internals to the engine. The only way to find out is to tear it down. Why?
